i am gone, there is but you can't see
  • Thread starter Thread starter Il Mauri
Il Mauri
Good morning to all, I found this problem this morning:
I loaded a set composed of various parts and assemblies and everything is not visible. all the components are present but you do not see anything, it is as if everything was out of the graphic area. I then tried to make an idw by charging the "invisible" axieme and this normally appears on the drawing.
Who can help me?
thanks and good work.
in the file manager the components are all visible and not suppressed, what is missing is the display on the screen.
to prove that everything is present the table works regularly and the whole axieme appears.
Isn't there any details off? test to select current view representation -> dx key -> all visible elements
No, it's okay.
I turned off last night and it was all right, and the problem came on this morning. I tried to place a new component and also this while appearing regularly in the file manager is not visible.
only now I realize that the axieme is visible in the main view representation (the one with the padlock), but with the colors of the fully packed components.
in fact in the usual work view (the default)(which is that I no longer see) I had customized the colors of the components.
Once something like this happened to me, I forgot to have activated a view in the section and the effect was exactly what you described (including "entry" to understand what it was). You ever want...
question. .
Did you start the "section view"? ? ?
and by mistake is he taking a "extreme" plan to the model? ? ?
is that you have put a very far-off component because of a bond and so all the displayed image appears very far away from it to seem that there is nothing? ?
try to suppress all components and remove the suppression to one by one to seese starting from the first you can see everything
solution n° xx
zoom extension, with the selection window cover the entire screen area and see if the drag dots appear.
If you see them, alternatively place yourself on the orthogonal planes of the views and drag the most distant components to the center of the world.
Bye.
or, as an alternative to what is suggested by stefano, take a component from the model tree and do find in window
Oh, that's nice. I'm not gone, but on Friday at 5:00 p.m., I'm going to die.
However I know that the file has some problem, probably using it as a study set and then uploading and deleting numerous assemblies, subassiems and parts probably is "salted" something. Boh?
