i look for autocad mechanical 2014 acad.pgp files in english
  • Thread starter Thread starter Marco74
Marco74
hi, I wonder if someone can pass me the "acad.pgp" file of autocad mechanical 2014 in English, I find myself much better with quick commands in English rather than in Italian.
if you like the 2013 one...
; external command format:
; <command name=""/>,[<Shell request>],<bit flag="">,</bit>[*]<prompt>,
; the bits of the bit flag have the following meanings:
; bit 1: if set, don't wait for the application to finish
; bit 2: if set, run the application minimized
; bit 4: if set, run the application "hidden"
; bit 8: if set, put the argument string in quotes
; examples of external commands for command windows
del, del, 8,file to delete: ,
dir, dir, 8,file specification: ,
sh, , 1,*os command: ,
shell, , 1,*os command: ,
start, start, 1,*application to start: ,
type, type, 8,file to list: ,
; examples of external commands for windows
; see also the (startapp) autolisp function for an alternative method.
explorer, start explorer, 1,,
notepad, start notepad, 1,*file to edit: ,
pbrush, start pbrush, 1,,
; command alias format:
; <alias>,*<full command="" name="">
3a, *3darray
3dmirror, *mirror3d
3dnavigate,*3dwalk
3do, *3dorbit
3dp, *3dprint
3dplot, *3dprint
3dw, *3dwalk
3f, *3dface
3m, *3dmove
3p, *3dpoly
3r, *3drotate
3s, *3dscale
a, *arc
ac, *baction
adc, *adcenter
aectoacad, *-exporttoautocad
aa, *area
al, *align
3al, *3dalign
ap, *appload
aplay, *allplay
ar, *array
-ar, *-array
arr, *actrecord
arm, *actusermessage
-arm, *-actusermessage
aru, *actuserinput
ars, *actstop
-ars, *-actstop
ati, *attipedit
att, *attdef
-att, *-attdef
ate, *attedit
-ate, *-attedit
atte, *-attedit
b, *block
-b, *-block
bc, *bclose
be, *bedit
bh, *hatch
blendsrf, *surfblend
bo, *boundary
-bo, *-boundary
br, *break
bs, *bsave
bvs, *bvstate
c, *circle
cam, *camera
cbar, *constraintbar
ch, *properties
-ch, *change
cha, *chamfer
chk, *checkstandards
cli, *commandline
col, *color
colour, *color
co, *copy
convtomesh, *meshsmooth
cp, *copy
cparam, *bcparameter
crease, *meshcrease
createsolid, *surfsculpt
csettings, *constraintsettings
ct, *ctablestyle
cube, *navvcube
curvatureanalysis, *analysiscurvature
cyl, *cylinder
d, *dimstyle
dal, *dimaligned
dan, *dimangular
dar, *dimarc
jog, *dimjogged
dba, *dimbaseline
dbc, *dbconnect
dc, *adcenter
dce, *dimcenter
dcenter, *adcenter
dco, *dimcontinue
dcon, *dimconstraint
dda, *dimdisassociate
ddi, *dimdiameter
ded, *dimedit
delcon, *delconstraint
di, *dist
div, *divide
djl, *dimjogline
djo, *dimjogged
dl, *datalink
dli, *dimlinear
dlu, *datalinkupdate
do, *donut
dor, *dimordinate
dov, *dimoverride
dr, *draworder
dra, *dimradius
draftangleanalysis, *analysisdraftangle
dre, *dimreassociate
drm, *drawingrecovery
ds, *dsettings
dst, *dimstyle
dt, *text
dv, *dview
dx, *dataextraction
e, *erase
ed, *ddedit
el, *ellipse
er, *externalreferences
eshot, *editshot
ex, *extend
exit, *quit
exp, *export
ext, *extrude
extendsrf, *surfextend
f, *fillet
fi, *filter
filletsrf, *surffillet
freepoint, *pointlight
fshot, *flatshot
g, *group
-g, *-group
gcon, *geomconstraint
gd, *gradient
generatesection, *sectionplanetoblock
geo, *geographiclocation
gr, *ddgrips
h, *hatch
-h, *-hatch
he, *hatchedit
hb, *hatchtoback
hi, *hide
i, *insert
-i, *-insert
iad, *imageadjust
iat, *imageattach
icl, *imageclip
im, *image
-im, *-image
imp, *import
in, *intersect
insertcontrolpoint, *cvadd
inf, *interfere
io, *insertobj
isolate, *isolateobjects
qvd, *qvdrawing
qvdc, *qvdrawingclose
qvl, *qvlayout
qvlc, *qvlayoutclose
j, *join
jogsection, *sectionplanejog
l, *line
la, *layer
-la, *-layer
las, *layerstate
le, *qleader
len, *lengthen
less, *meshsmoothless
li, *list
lineweight, *lweight
lman, *layerstate
lo, *-layout
ls, *list
lt, *linetype
-lt, *-linetype
ltype, *linetype
-ltype, *-linetype
lts, *ltscale
lw, *lweight
m, *move
ma, *matchprop
mat, *matbrowseropen
me, *measure
mea, *measuregeom
mi, *mirror
ml, *mline
mla, *mleaderalign
mlc, *mleadercollect
mld, *mleader
mle, *mleaderedit
mls, *mleaderstyle
mo, *properties
more, *meshsmoothmore
motion, *navsmotion
motioncls, *navsmotionclose
ms, *mspace
msm, *markup
mt, *mtext
mv, *mview
networksrf,*surfnetwork
north, *geographiclocation
northdir, *geographiclocation
nshot, *newshot
nview, *newview
o, *offset
offsetsrf, *surfoffset
op, *options
orbit, *3dorbit
os, *osnap
-os, *-osnap
p, *pan
-p, *-pan
pa, *pastespec
rapidprototype, *3dprint
par, *parameters
-par, *-parameters
param, *bparameter
partialopen, *-partialopen
patch, *surfpatch
pc, *pointcloud
pcattach, *pointcloudattach
pcindex, *pointcloudindex
pe, *pedit
pl, *pline
po, *point
poff, *hidepalettes
pointon, *cvshow
pointoff, *cvhide
pol, *polygon
pon, *showpalettes
pr, *properties
prclose, *propertiesclose
props, *properties
pre, *preview
print, *plot
ps, *pspace
psolid, *polysolid
ptw, *publishtoweb
pu, *purge
-pu, *-purge
pyr, *pyramid
qc, *quickcalc
qcui, *quickcui
qp, *quickproperties
r, *redraw
ra, *redrawall
rc, *rendercrop
re, *regen
rea, *regenall
rebuild, *cvrebuild
rec, *rectang
refine, *meshrefine
reg, *region
removecontrolpoint, *cvremove
ren, *rename
-ren, *-rename
rev, *revolve
ro, *rotate
rp, *renderpresets
rpr, *rpref
rr, *render
rw, *renderwin
s, *stretch
sc, *scale
scr, *script
se, *dsettings
sec, *section
set, *setvar
sha, *shademode
sl, *slice
smooth, *meshsmooth
sn, *snap
so, *solid
sp, *spell
spl, *spline
splane, *sectionplane
splay, *sequenceplay
split, *meshsplit
spe, *splinedit
ssm, *sheetset
st, *style
sta, *standards
su, *subtract
t, *mtext
-t, *-mtext
ta, *tablet
tb, *table
tedit, *textedit
th, *thickness
ti, *tilemode
to, *toolbar
tol, *tolerance
tor, *torus
tp, *toolpalettes
tr, *trim
ts, *tablestyle
uc, *ucsman
un, *units
-un, *-units
uncrease, *meshuncrease
unhide, *unisolateobjects
uni, *union
unisolate, *unisolateobjects
v, *view
vgo, *viewgo
vplay, *viewplay
-v, *-view
vp, *ddvpoint
-vp, *vpoint
vs, *vscurrent
vsm, *visualstyles
-vsm, *-visualstyles
w, *wblock
-w, *-wblock
we, *wedge
wheel, *navswheel
x, *explode
xa, *xattach
xb, *xbind
-xb, *-xbind
xc, *xclip
xl, *xline
xr, *xref
-xr, *-xref
z, *zoom
zebra, *analysiszebra
; the following are alternative aliases and aliases as supplied
; in autocad release 13.
av, *dsviewer
cp, *copy
dimali, *dimaligned
dimang, *dimangular
dimbase, *dimbaseline
dimcont, *dimcontinue
dimdia, *dimdiameter
dimed, *dimedit
dimted, *dimtedit
dimlin, *dimlinear
dimord, *dimordinate
dimrad, *dimradius
dimsty, *dimstyle
dimover, *dimoverride
lead, *leader
tm, *tilemode
; aliases for hyperlink/url release 14 compatibility
saveurl, *save
openurl, *open
inserturl, *insert
; aliases for commands discontinued in autocad 2000:
aad, *dbconnect
aex, *dbconnect
ali, *dbconnect
asq, *dbconnect
aro, *dbconnect
ase, *dbconnect
ddattdef, *attdef
ddattext, *attext
ddchprop, *properties
ddcolor, *color
ddlmodes, *layer
ddltype, *linetype
ddmodify, *properties
ddosnap, *osnap
dducs, *ucs
; aliases for commands discontinued in autocad 2004:
acadblockdialog, *block
acadwblockdialog, *wblock
adcenter, *adcenter
bmake, *block
bmod, *block
bpoly, *boundary
content, *adcenter
ddatte, *attedit
ddim, *dimstyle
ddinsert, *insert
ddplotstamp, *plotstamp
ddrmodes, *dsettings
ddstyle, *style
dducs, *ucsman
dducsp, *ucsman
ddunits, *units
ddview, *view
dimhorizontal, *dimlinear
dimrotated, *dimlinear
dimvertical, *dimlinear
doughnut, *donut
dtext, *text
dwfout, *plot
dxfin, *open
dxfout, *saveas
painter, *matchprop
preferences, *options
rectangle, *rectang
shade, *shademode
viewports, *vports
edwfx, *exportdwfx
edwf, *exportdwf
epdf, *exportpdf
-qpub, *-export
; aliases for commands discontinued in autocad 2007:
rmat, *matbrowseropen
fog, *renderenvironment
finish, *materials
setuv, *materialmap
showmat, *list
rfileopt, *renderpresets
rendscr, *renderwin
; aliases for commands discontinued in autocad 2009:
dashboard, *ribbon
dashboardclose, *ribbonclose</full></alias></prompt>
quelli di acadm
bal, *amballoon
cb, *amcencrhole
cha, *amcham2d
cl, *amcentline
clin, *amconstlines
cloo, *amclineo
cr, *ammanipulate
cs, *amcencross
dan, ampowerdim_ang
dau, *amautodim
dmed, *amdimmedit
f, *amfillet2d
h, *amuserhatch
Hioo, *amlayinvo
l0, *amlayer_con1
l1, *amlayer_con2
l2, *amlayer_con3
l3, *amlayer_hidw
l3n, *amlayer_hidn
l4, *amlayer_hlin
l5, *amlayer_dili
l6, *amlayer_txt3
l7, *amlayer_cenw
l7n, *amlayer_cenn
l8, *amlayer_hatch
l10, *amlayer_vpli
l11, *amlayer_phan
lg, *amlayergroup
lgmo, *amlgmove
lgv, *amlayvisenh
lib, *amlibrary
lm, *amlayer
lmo, *amlaymove
o, *amoffset
oo, *3dorbit
par, *ampartref
PC, *ampowercopy
pd, *ampowerdim
ped, *ampoweredit
for, *ampowererase
prc, *ampowerrecall
proo, *amlaypartrefo
pss, *ampowersnap
q, *amdwgview
qq, *ameditview
rec, *amrectang
s1, *ampsnap1
s2, *ampsnap2
s3, *ampsnap3
s4, *ampsnap4
sm, *amscmonitor
stoo, *amlayparto
tioo, *amlaytiblo
txl, *amlangconv
u0, *amunit_0
u1, *amunit_1
u2, *amunit_2
u3, *amunit_3
u4, *amunit_4
v1, *amviewul
v2, *amviewur
v3, *amviewll
v4, *amviewlr
v5, *amviewcen
Okay, *amviewall
vpoo, *amlayvpo
be careful that a pgp is a simple substitution (usually abbreviation) of the command that the pgm is in degrees to recep.
I try to explain myself better:
autocad English versioncp, *copy
autocad Italian versioncp, *copyThe syntax is alwaysabbreviation, *naming. the comma after the abbreviation, at least one space (but also a tab is fine) and the asterisk are mandatory.
goes as if that by simply replacing the pgp of an acad eng with that of acad in ita is assigned the abbreviation of the English one, but also the relative command and acad will return an error (command not recognized) because the command copy in the acad in ita is not transposed. wants the command copy or (I don't know if macanical has the same prerogatives but I assume it is a vertical product) the command _ (all nationalized versions of acad are commanded by the corresponding English commands preceded by the underscore).
but then having to change all the voices of a pgp eng on a version ita anteponendo an underscore to all the commands, it is not worth modifying only the abbreviations?
But I noticed (previous versions) that in pgp not always commands in English with _ work
work from command line, from pgp no... Unless there's any trick I don't know...
quelli di acadm
bal, *amballoon
cb, *amcencrhole
cha, *amcham2d
cl, *amcentline
clin, *amconstlines
cloo, *amclineo
cr, *ammanipulate
cs, *amcencross
dan, ampowerdim_ang
dau, *amautodim
dmed, *amdimmedit
f, *amfillet2d
h, *amuserhatch
Hioo, *amlayinvo
l0, *amlayer_con1
l1, *amlayer_con2
l2, *amlayer_con3
l3, *amlayer_hidw
l3n, *amlayer_hidn
l4, *amlayer_hlin
l5, *amlayer_dili
l6, *amlayer_txt3
l7, *amlayer_cenw
l7n, *amlayer_cenn
l8, *amlayer_hatch
l10, *amlayer_vpli
l11, *amlayer_phan
lg, *amlayergroup
lgmo, *amlgmove
lgv, *amlayvisenh
lib, *amlibrary
lm, *amlayer
lmo, *amlaymove
o, *amoffset
oo, *3dorbit
par, *ampartref
PC, *ampowercopy
pd, *ampowerdim
ped, *ampoweredit
for, *ampowererase
prc, *ampowerrecall
pss, *ampowersnap
q, *amdwgview
qq, *ameditview
rec, *amrectang
s1, *ampsnap1
s2, *ampsnap2
s3, *ampsnap3
s4, *ampsnap4
sm, *amscmonitor
stoo, *amlayparto
tioo, *amlaytiblo
txl, *amlangconv
u0, *amunit_0
u1, *amunit_1
u2, *amunit_2
u3, *amunit_3
u4, *amunit_4
v1, *amviewul
v2, *amviewur
v3, *amviewll
v4, *amviewlr
v5, *amviewcen
Okay, *amviewall
vpoo, *amlayvpo
