i look for help to learn nx from 0
  • Thread starter Thread starter Utente cancellato 62108
I am new to the forum and I would like to approach the use of nx.
I would like to try to change work and weight that the use of this sw can help a lot, especially because I would like to approach the marine industry.
I already know 3ds max, a little maya, autocad, proe and photoshop.
I would like to try for the moment a self-taught approach.
Could someone give me a little training?
Can you give me some advice?
thank you 1000,
ivan
thank you 1000,
ivan
Good morning,
contrary to catia, there is not much material on the net (as opposed to catia that there are also whole courses available on the net). I recommend you.
there are pdfs in the network that teach the basics of nx. I would start with you to at least have a flourishing of the main commands (create a model, together) later I would deepen these (maybe learning a bit of top-down) and then pass to the modules connected to it.
another advice is why to use nx and not another cad? What are his strengths? this so that you can make the most of the main qualities of this cad (on this forum you will find something already). .
thank you 1000,
ivan
nx is a very special cad, before learning the commands, one should understand the philosophy. I do one example: it is the only cad that has a single extension for .prt files, in which you can, always for example, draft inside or outside the model. These peculiarities influence the way to operate.
Hello, guys.
thanks for the quick answers.
I also thought I would approach us a bit by degrees, following tutorials, videos on youtube and material that you can find on the net.
I just don't want to put too much on it, I learned 3ds max almost totally alone with tutorials on the net and manual paper, but it was time when I had much more time to get lost on it.
I personally find myself a lot of apples studying on manuals or paper books compared to the material on the net.
However aimè, bei vademecum to download I did not find it and I think a series manual goes on 150€.
I will bear in mind the particularities you have mentioned and the particular approach to modeling which requires nx.
I don't know what you're talking about.
but it will be only because I still don't have the software and I'm trying to say it again.
I think it's a huge and difficult program, I read that they use it as well to orbit satellites and missiles. .
I'll throw it there.
I know that some users are sometimes available to give some private lessons in the area, or in video conferencing if from further away.
Of course not to ggratiseeee. . .
I'd like to do a few hours of class to speed things up.
will not suffice for you the 150 € mentioned before, you will want more if you want to continue writing on this forum (I am explained? ).
I think it's a huge, difficult program. I read that they use it to orbit satellites and missiles. .
and also users......:hahahahah:
