i lost the settings of the confi.pro
bizio_88
Something strange happened to me, and I wanted to know if anyone knows how to recover everything.
I use I create parametric 8.0.0.0, last update from us used in the company after various updates from version 4.0 / 4.2 etc. etc. generally the program I open it from the window application bar and right here arises the problem, last Thursday I clicked by mistake with the right and I inadvertently removed the connection from the taskbar, so far no problem, I search it in the pc and I remove it in the bar.
However from there on when I open the program is all packed, it works, but it does not have the config.pro as it was set last week.
Does anyone know what can happen and how to recover?
good morning, in the properties of the link there is the voice "from".1711373458387.webpyou have to put the path of the folder that contains the config.pro.
Bye-bye.
Thanks for the time to answer.
in the end I solved thanks to the energies of the post lunch:)
I don't know why, I had the default config.pro saved in the disk c folder of the pc while the real config.pro (the one I work with) was in the document folder.
We probably created it together with the ptc technician for not knowing what reason, many years ago.
It must be solved. thanks to all
