Parametric_Ozzy
Hunting doesn't seem to me that siemens or other swhouses give you things.It's a problem with the former cocreates, now ptc. Once I had seen what it was for to cocreate to do (male) the same things I did with my solid edge of 3000 euros: I went to spend on 20,000 for a post.
do you mean if you have to pee a little serious you put us less with your basic solidedge of 3000 euros that instead buy you a xpresroute of solidedge rather than the mechanical routed system of nx?
I do not doubt that you can do it even without module, as you can do it in creo or other sw, only that it is probably lightly more expensive and if you do some piping every now and then you probably don't want to, but if you do often I think that the investment will save you a lot of time because they are vertical modules developed specifically for that field of use.
