identify block to change
  • Thread starter Thread starter Esselle
Esselle
Good morning, when I go to act on a block that contains other blocks I am usually select it-monitoring direct block and then I scroll through the window until I find the right one to change.
Is there a system with which to select the block to change more easily?
I go to memory... if you set the doubleclick so that it launches the block change when you do it on the nested block is opened that
with the double click I have now does not work, now I see if I find where you set.
edit : I have already set change by double click
the action doubleclick the impetus in the customization of which.
I don't have autocads in my memory, as I said.
However perhaps I am confused with the change with reference (modrif) that does not open the specific block in the block editor, but opens it in the context of the design.
you mean this setting I think:
modifica.webpdouble-clicking opens the whole block in the block editor and not in the context of the design, at least the block on which I double-clicked.
the solution is the modrif command, which does exactly what I want, now I try to make the right button appear on the toolbar!
Thank you, as always, thank you.
but to make a button appear on the autocad bar you have to be programmers or the limitation is mine?
I would like to put there, where I made the blue circle a button that restores the modrif command.
Cattura.webpIf you have a guide, I will be grateful, thank you.
Thank you, I couldn't do what I wanted, but I solved by removing the button creates block and I put the other one.
Of course it's not that intuitive. . .
but the command you are looking for is not that in the lock tab?
However, in the customization area, expand the tab in which to enter the command:
For example:
blocking
- insert
-create
-modification
-ed attributes
-what you transfer the new command from the bottom list of the customization card
