identify old releases files
  • Thread starter Thread starter Tarkus
custom search is easy, from explore resources I don't know how to... However, it could copy/seat the files automatically into the folder with the rel name.
However the process of reorganizing folders often stacks everything with the search of files to reconnect the files that are no longer in the right path, as happened to matteo hats some post does if I do not remember badly.. .
Matteo, if you read us, how did it end?
I give you two if you pull out of your magic hat a macro that only lets me locate the files of the versions I'm wearing.
e.g.: in this folder, list only the files of 2014 and 2016.
if you could do it directly on explore resources so you can select them and move them or delete....you get to 5 beers :36_1_13: :36_1_13:
design assistant does not filter versions but you group them in ascending or descending order and then copy and move files
