idw in dwg zip
  • Thread starter Thread starter GreenChuck
GreenChuck
Hello, everyone. my problem this time is to expose the harvests to the table (idw) in the cad format (dwg). I tried either with "export", or even saving by name, but the result is that it creates a zipped file and every time I have to extract it. . .
p.s. before this problem there was therefore "think" both in the settings but I do not know where to put hands...
Who gives me a hand??? ? :confused::confused
inventor 2012
ahahah :) In fact, I had answered but it seemed to me the case of creating an appropriate discussion.... however, in my case does not appear that screen you have attached... I tried to cuff but the files me zip them all!!!:mad:
What are you doing? Export and choose dwg autocad (i.e. don't throw a fleeting eyelet and see that at the bottom there is written .dwg and think "good, is already on .dwg"), just selecting it (default export to inventor .dwg) and then press the options button next to it? and do it manually at least the first time, or open the table, do you export blah blah? if you do not do the first export manually then I believe zippi everything, otherwise as already said (not just by me) keeps the setting of the last manual export.
thanks catafract for your availability :) when I had to save by name I went on options and set a configuration different from the default one. it is enough to reset it to solve the problem... thank you!!!!!!!!!! :wink:
