idw table size block
21pye21
I have a request about the idw table, in particular I would need to know if there is a possibility to block the drawing proportion in the sheet, as it can be for example in an a4.
to explain myself better, having a pre-set table with views and assuming that these views never change as a perspective but only in size (let's say that I insert bigger or smaller pieces), can I block them and make the program act directly on the scale of the view?
Thank you all. :biggrin:
