idw to dwg
slashzakk
Hello everyone!! :smile:
I have a problem with export from idw to dwg to inventor.
when I take the tables the text of certain symbols, quotas and notes passes from romans to romansiv25 or from isocp to isocpiv25.
Why does the program behave like this?
I tried to set the export settings in the most varied manners but without having a good result, I thought the switch from one program to another was easier while it is the same mother house to provide them... What do you recommend me to do?
Thank you in advance.
I had the same problem as soon as I started using inventor is solved so, executed export of a generic table in dwg, then from this dwg I set the layers and notes as I wanted and then this I saved dwt model and inserted into the conversion options.
