if st1, available sp10
I happen to happen! then I signed up on thunderbird at the American newsgroup, so I'm pretty soon getting notifications!
You have to use a mail client (I use thunderbird, but I also think outlook is good), the server address is:
bbsnotes.ugs.com(there is also a web interface: http://bbsnotes.ugs.com but it's pretty unusable, almost worse than the st leash)
requires authentication, for which your webkeys normally use to access the ftp server of updates.
among the various groups of disponibli, you can choose solid_edge.misc which is the general discussion.
Among other things, he's frequented by some siemens employees, so reporting bugs there instead of propio reseller may be more profitable.
even in this mp have not solved what so bad, surely the problem is in the sheetmetal environment: if in a sheet a vased hole is made and the vasation goes to affect the opposite part (in a few words it goes beyond the nominal diameter of the hole) when exporting to dxf the developed, although in the export options it has been disabled "complex hole" at the poured hole is exported both the nominal diameter and the vasation diameter....forse one day will be arranged.
Bye.
