illustrator problem export file eps
  • Thread starter Thread starter sigur ròs
sigur ròs
Hello everyone, I'm setting up the these tables with illustrator cs4 and I have a problem on exporting a legend.
clarify....I carry dwg files into illustrator transforming them first into eps...and I never had problems...until when I tried to export an eps file consisting of a legend (legend of degradation) that is composed of photos and written.at the moment of the illustrator opening tells me "the processing can not be completed because the memory is insufficient.some objects could be damaged or missing."
I tried to decrease the definition... to divide it into smaller parts... to change the scale...but I didn't fix anything.
I press that these files are as much smaller sizes than others that instead do not give me opening problems.
someone can help me....thank you in advance!! !
