antimetro
I have a problem with the ilogic browser, in theory when I add a rule I should see it in the rules list inside the broswer, this does not happen, it is an hour I turn but I can not find the solution. the rule exists as I see it if for example I want to integrate it within a module but I can't see it in the browser and so I can't edit it.
I'm learning right now to do the first things with inventor regarding ilogic, I have to do it to create some scripts at a time to make some automations.
Thank you very much for every kind of help you give me.
p.s. use inventor professional 2014 and you also use the vault to share projects.
