i'm sorry.
gsandron77
I made a project with table variants in ipart, a particular format from multiple welded pieces.
I would like to generate a set of the various versions, but I have now generated files but it does not leave the possibility to generate components and nothing else.
how can I overcome the problem, to succeed in coding and quotating all the various details / bodies?
I would like to keep everything tied up for possible changes in the future.
If I understood correctly, you modeled your object as part multybody, then you created the ipart with the various versions.
In my opinion, it generates part, it creates the assemblies containing the various derived parts of the current line of your ipart.
I have not tried, but, logically, if you activate a new line of the ipart, and then generate the aid again, if you save it with another name, you should get the new together with the modified dimensions.
I have little experience with the iassembly, but those I have realized, I have made them like this:
created individual iparts
created the file together and entered the various iparts and bound the whole
to this point transformed the file together in iassembly (family of together)
in the table rows, you can select the various ipart combinations, generating your configurations
allego sample files
Good job
