image file
  • Thread starter Thread starter andrea9875
andrea9875
hi to everyone, I tried to insert in the cartiglio of a file drawing of inventor,an image, among other you can put only bmp...
All right but at the moment I go to print the image there is no more...if I do the print preview the image turns out deformed. . - Does anyone know how to explain?
First of all, maybe you should introduce yourself to the appropriate section.poi for when it comes to your problem, it would be better if I wrote the procedure that you adopt to insert images also because I think they can also put the jpg.cosi files maybe we can understand where to act.
You're right. I've got it now.
what I do is: I go to the browser in the folder "drawing Resources"-cards-iso-right key and "change"; then opens the sketch to change the cart.
I then go to the "Insert" section, click on "image", click with the mouse where I want to insert it and open the image search window with the only available format "bmp" (I use inventor 2011). I insert the image that I saved in "bmp", the size as I need and everything works, you see in the right way.as I have already said if I go to print the drawing the image does not appear, if I look at the preview of the print I see deformed...I have already found with "search" in the forum a discussion about a logo in the cartiglio but apparently did not come to a solution. . .
