image (jpg) in a part
  • Thread starter Thread starter valtic
valtic
Hello everyone!
I ask you for your help in inserting an image in a part.
banal example and without turning too around:
I have a 400x250 sheet thickness 0.5 on which I would like to apply an image of 400x250 mm (previously produced with photoshop) and here is a nice mess!
it seems impossible, I also did a search on the forum but I found unclear answers!
the purpose is to see the image sneezed on the surface of the part and consequently on the axieme.
thanks in advance :smile:
I don't know if this way can do to your case. after making the sheet, apply to the same any material and set the display in "shading with material". Then right click on the material applied in the logical tree and go to property: in the menu "rese" you can replace with the command browse the image that will use for displaying the material. remove the tick from "ripeti u e v", in your case you do not need a single image and being already in scale 1:1 you do not have to adapt it, at most you have to center them, however they are
commands quite intuitive.
I'll train you a screen with a flight test. the limitation of this method is that you have to display everything (also the assieme) in material mode... Try a little... I hope I've been helpful, bye.
