Agar
we are in autocad 2006
in the dwg file to you have inserted images that are in the f folder then each image will have its own saved path displayed in insert > image management
1) In case you need to move the folder to another location I will always have to “image management” for each image with browse to locate the new path and then reload it with “reload”. I ask if I have to do the process for every single image or if there is a way to save the new path once and for all since there are many.
2) if I have to change the name of the folder where the images from f to f1 are found I always owe for each image with browse to locate the new path and then reload it with “reload”. I ask if I have to do the process for every single image or if there is a way to save the new path once and for all since there are many.
