image rendering problems
  • Thread starter Thread starter Maurorevit
Maurorevit
Good morning.... I am a new member to the forum and I take advantage of greeting all users.
use autocad and revit for a long time and for a few days I have a problem with revit version 2012 that
I think it can come from a recent update of windows 7. in fact if I carry out a rendering and save it in the project to
reopening the image the colors are altered. if on any view (for example plant) I create a color writing
red the blue view. If I load an image I see it with always altered colors. even the color of the selection is no longer congruent. all these phenomena disappear if the hardware acceleration disables. the driver of the graphics card installed is the one tested and recommended by autodesk and in the alerts no problem related to the pictures is reported.
I'd like to know if someone found the same problem. Thank you.
:smile: good morning
I believe I have solved the problem, so I communicate the solution in case someone is still in trouble.
the problem is created by a conflict with an update of windows 7 and precisely:
"updates of the platform for windows 7 x64 (kb2670838)"; you need to uninstall the update and restart
the pc and colors return to their place even with hardware acceleration activated.
I hope I was useful to someone.
It's true the other morning happened to me.
after upgrading win 7 I found all the internal images of a job I was doing
with inverted colors
I restored immediately removing win 7 updates
revit outdoors and the colors had returned normal
