import dgn file format
  • Thread starter Thread starter qui
qui
Hello, everyone.
I got a drawing in the phoney dgn.
I know it is a "competitive" of the dwg format.
Now I find myself in the need to open the file and save it in dwg...
Is there any application to do that?
steak
I think you have to ask someone who has microstations...maybe here on the forum.
with map 2006 there is in the third cd the application for autocad map to import dgn files
I believe that in the later versions of 2006 maybe even normal autocad has been inserted natively
look that from autocad, (depending on the version) once you have an open file, you can from the file menu, under the item it matter to choose dgn and upload a microstation file. Obviously you have to hope to have a version of the dgn file that is not too new otherwise autocad does not open it. in case you can also use rhinoceros to do so. (always you have it)
the importdgn command was included in autocad from the 2008 version, and import dgn v7/v8 format.
