import dwg on inventor sketch
  • Thread starter Thread starter kiki
kiki
hi! I had to make a 3d with autodesk inventor.
I prepared the design of the buildings in 2d with autocad so to have the correct location of the buildings that then I will go to 3d. I then imported the .dwg file in inventor. How do I now pass from the dwg to the inventor sketch?because importing it I can't draw on it. .
Thank you! !
I am writing to use and consumption of the administrator and/or moderator, but I am pleased that they read it all:
you can remove the thread "new inventor users present here".
No one needs any more...
I did not understand the question well, but I try to answer you:
then from the autocad dwg you can only quote it and not change it.
If you want to import autocad skizzi and process them, you have to follow a series of steps that make the procedure effective I make you a video and load it up, but I have to detach the audio because I have children playing. the program and in German but you could follow the mouse and we hope it will serve something
:finger:
