valtic
Hello everyone,
use autocad 2010 fired, I have a problem with importing files *.3ds :frown:
basically when I try to import a file from the menu insert > 3d studio...> pippo.3ds returns the error: 3dsin impossible to find the control file of the dialog boxes render.dcl.comando unknown "3dsin". press f1 for the guide.clearly in the guide is not explained how to solve the problem... the only thing I did was to completely reinstall autocad successfully! in the sense that I did not find any problem in the first imports, then puff!!! Everything like before...
I looked for other solutions on the internet but nothing.. and then the file "render.dcl" is present in the system so I don't see why you don't find it.
will there be a way to restore this window control file dialog?
or even better to understand why the first time it works and then it disfigures. .
Thank you:
yellow
Thank you:
yellow
