import font...
  • Thread starter Thread starter VALEBASO
VALEBASO
Good evening, did anyone import new fonts to replace existing ones?
I would like to create a cartiglio and use the characters that in world are named arial and arial narrow... or someone knows the nx...
They are struggling with a lazy mooolto. . .
That's right.
That's right.
I don't know much about fonts, but if you have to write like: "All rights reserved blah blah blah blah blah blah blah" I would do it with standard fonts. If you want to make a logo or a pretty short writing, I suggest you do it in coreldraw, to save the outline in dwg format and import it into your pattern/folder. You will avoid any problem.
attached you will find the factory font application. It's a freeware.
came to v2.5 (I think it will be the last produced).
inside the zip you will find:
- the installation kit (renamed in exe, of course)
- a pdf explaining its use and limitations
