Spy
Hello everyone, I am a brand new user with a small problem: Does anyone know the import procedure nx files (created in unintegrated ambient) in teamcenter engineering? ?
Thank you very much
alex
Thank you very much
alex
from nx integrated:Hello everyone, I am a brand new user with a small problem: Does anyone know the import procedure nx files (created in unintegrated ambient) in teamcenter engineering? ?
Thank you very much
alex
at the present time, the import in tc:importing a set in tc can really become an adventure.. .
where I work often happens to do it but every time there are several difficulties.
the mode recommended by siemens is to use nx in tc environment, menu "file" -> "import together in teamcenter".
opens a window like the "clona" command.
1-in the main window "main" select the default action for all components (maintain existing or overwritten). if there are already existing components in tc can be preserved or overwritten.
2-go to the "load options" (load options), select the interest option and click on "add assembly" (add assembly) by selecting the axieme to import
3-go to "numbering" (numbering), select the default item type that will be assigned to the components. if the file names perfectly reflect the name that will be assigned in tc then select in the window "convert automatically" (auto translate)
4-the other options you can leave them as they are (unless exceptions)
5-Return to "main", click on "set defaults" and (unless you have selected "auto translate" before) enter one by one the names of the components to be assigned
6-select "dry run" and then "execute" to see that there are no errors
7-if there are no deselect "dry run" errors and click nuivamente on "execute".
8-pray that everything goes well (usually never happens).
alternative
1-creates one by one items in tc
2-in each item creates a ugmaster type dataset and imports the solid model of its component
3- possibly create one or more dateset ugpart to import boards
4-after creating and importing each component, subaxieme and together open all subaxiemi and axiemi and replace one by one components so as to load the newly imported ones
In any case I take the opportunity to reiterate that the import of axes in tc is often a bloodbath.
I think that in the mode recommended by siemens it is necessary to ask for the names of parts not more existing or renamed in the initial axieme... here really should study something more decent!
