import obj created in rhino on the pads
  • Thread starter Thread starter elisa massari
elisa massari
Hello.
I have a problem.
I downloaded an application for pads called vertostudio 3d that allows you to rotate 3d objects or move them. .
the application only imports obj file format created as mesh and not as nurbs.
Although he manages to transform objects created as nurbs in mesh in rhino.
the pad does not recognize them, while objects created directly in rhino like mesh are imported correctly.
I don't know what to do. .
Thank you very much!
I downloaded it and it works great!
without you I wouldn't have come to the head
Thank you again!
I agree it works fine though I don't know if you have the same problem, it doesn't display the rendering properly...... to me upload them but the only possibility is to change the background...the object displays it in gray even if it is loaded rendered with metal effects etc....to you do the same or do I miss some export passage? Hi.
