MckJapan
hello to all, I'm new and apologize if the subject has already been treated / the section is not correct.
I'm starting to use inventor to learn how to use it with autocad 2d I've been using for years.
I have followed some basic courses on youtube and recently I am trying to create a rack for co2 cylinders, the rack itself consists mainly of 5mm plates and profiled to l, welded to each other / bolted.
I designed all the various parts I need, and I imported them into the drawing together, but I have a problem, the components are not perfectly vertical or horizontal, but they have a slight different angle between them, which creates some problems with the holes.
is it possible to import the parts perfectly horizontal or vertical compared to the axles during import?
of course the parts were designed perfectly in axis.
