import points
  • Thread starter Thread starter Mauro66
Mauro66
Hello everyone, I am struggling with the import of data of a revit ground; I tried both creating a .csv or .txt file according to the indications of the autodesk site, and importing the design as shown in the following tutorial:https://www.youtube.com/watch?v=_m1ybqqoijkbut I can't get a spider out of the hole, that is all I get is a vertical line inside the 3d view, as you see in the image I attach:Immagine.webpWhere am I wrong?
thank you and good Halloween to all.
0.0018,-0.0004,-370.000
0.0018, -0.0004,-370.000
0.0017,-0.0004,-370.000
0.0017,-0.0005,-370.000
-0.0018,-0.0001,-360.000
Are you kidding me? What are these coordinates?
30 rows of points, then have actually only 4 different coordinates
I would give a controlled file .txt and .csv
I moved the original dwg file into space to bring it as close as possible to the coordinates of my revit model
Forgive me, mauro, but I miss a ride... which has the dwg involved? What dwg are you talking about?
you are right tristan, I extrapolated a portion of territory with qgis, I created the level curves, extracted the knots of the same always in qgis. then in autodesk civil 3d I processed my quoted points creating the txt and csv files that I attached above, not before having "translate" my piece of land near the coordinate 0.0, so to find me centered once imported everything in revit. for completeness I say I also tried to "low" the quotas of m. 630 to work them to the levels of the same model.
You really did the goose ride, you know? But I'm sorry, if you give him the curves that were extrapolated by qgis, don't you do that first? or bad that go you create a surface in civ3d, carry it as dwg autocad and use that
