import step in inv2009
  • Thread starter Thread starter deba7171
deba7171
with inv2009 sp2 I can not open/import any step.
step generated with pro-e wf4 m040.
open well with think3.
Inv instead crashes at the loading and I have to finish the session.
Any suggestions?
Any suggestions?
if you go to "instruments" --> additional modules, find the "reversal program : step "?
I don't know think3, doesn't save in other formats valid for inventor?
I activated the add module but it does not open all the step files.
only some files (the most complex at features level) have import problems in inv.
Now I try to see if it is an entity limit problem when loading.
how long did you take before deciding to "fall" inventor?
Because if you say they're a little complex, it takes you....
think reasons for surfaces, first generates it (I think)... .
Usually the steps are the best for inventor, strange does not open them...
after the advice of stefanobruno I managed to open in a "fulminea" way the various tests I had prepared. so I could understand that it stuck to me for a single file.
I have to import a set of 180 parts (parts and subass.) and I couldn't for that only part. now in a blow I opened 179 perfectly (I have suppressed the "vigliacca" at the time of the exit step from proe), but I still can not charge the single kissed.
I attach the file for some good soul that wanted to verify the import.
tanks
open with inventor 2010 without problems... I saved it again as step (I don't know if you have inv2010). .
Try to see if it's in...
but let you give it directly in the proe format? 2010 imports it natively... for the previous versions if I don't remember badly there was a plug-in to be able to download from the labs...
with 2010 opens, with 2009 there is no verse ( sat - step - igs generated from 2010 ), it blocks with 698,416 kb of ram engaged.
thanks giga and stefanobruno for the sad confirmations. Unfortunately I only have inv2009 and the native proe there is it because I shaped it. only that the natives of wf4.0 only open from inv2010. :mad:
is there really no way to export (and correct) this file to be able to import it inv2009? I try to suppress some features to understand where you plant.
thanks for the supports
30, let's do 31... just to try, try to post the native of proe... we open it with inv2010 and save it in step (or some other format)... who knows, maybe it is just a conversion problem made by proes that nail the file to inventor.. .
I finally unlocked my stomach. :biggrin:
I generated from proe a step feature after feature until unmasking what planned me inv. suppressed that goes that it is a wonder.
I attach the image to the "anomala" feature.
the version of proe is the wf4 m040.
At the moment it gives me problems attaching the 3883 kb zip of the part.
I try later.
Let me know:
I opened it with inv 2008 and settled as ipt, can it be useful?
thanks Essille I will definitely use the part since it is complete.
at this point the question and related to inv2009 in the import of step. already in other discussions someone had problems with step.
thanks to all
Good luck
It is nice to see that the oldest rel. works better than the new.
by curiosity I opened the step with rel. 11 and, miracle, it works.
I converted it into 2009 and I train them both.
I try later.
Let me know:
Maybe he's not guilty, but the m040 is old, now we're at m091. that it is not a problem of exporting proes?
Unfortunately I cannot attach the prt file, but it would be interesting to understand whether it is a writing or reading problem or just one of those "strange" cases. is in fact that inv2008 and inv2010 open the step that 2009 does not open.
for my work are rare these import (for now), and we are planning the passage to 2010...
I still take the opportunity to thank you for the help without which I would still be firm. :smile:
thanks to all
Good luck
too good...:smile:
We're all here to help us, aren't we?
Bye!
