import step settings
MARCOC
Hello everyone1632922496401.webphow do you activate the import step setting screen? I find myself as from image all in gray and I can not change the settings
Thank you very much
Thanks massive... I ask you something else. ..why after many tests I don't go out... is there any way to import the steps directly into multibody, without making them create a blind with the parts inside? ? ?
I tried to select all the options, but the bearings always create them as together with inside balls and rings
depends on how the file was created and probably daccome was exported. but I don't see the problem, it opens it as a whole and when you save it you choose to do it as a part
