import
  • Thread starter Thread starter giocamb
giocamb
hello to all
I have a question about importing iges files.
I came from a client an iges file made with noug with a high precision, I put the line part inside the iges that if I haven't yet burned my brain should be 0.15
== sync, corrected by elderman ==
100211.141354,1.0e-005,10000.0,,11,0,15h20110211.141100;g 5
I tried to open it with wildfire3 and wildfire4 with the same config.pro
difference between 3 and 4 that 3 opens it a little better than 4 but it always sucks very hard to fix.
Some of you have already tested configurations that work well in importing iges.
test so, create a new blank part, set the accuracy of the part to 0.15 (the default pro/e, equal to 0.0012, is much higher) and then import the iges with insert data shared by file.
Let us know if you're running.
I always do this.
But the strange thing is that with wild3 comes on better than with wild4 that should be the opposite.
the other thing was precisely if there are already tested configurations for imports.
if you can use the 4 because you do not use the repair command?
with that you can fix a lot of the model, and helping you with the precision you should get a result more than acceptable.
If then the 3 you care better mix, count with the 3 and start with the 4.
