importa cad
  • Thread starter Thread starter Carmine71
Carmine71
hi, I have a problem with the import cad command: when I insert a file with the automatic option: from origin to origin, it does not allow me to select the imported geometry anymore in order to eliminate it. What's wrong? :confused:
the problem is only related to the selection or do you really not see the imported dwg? revit version?
the selection, displays it, but does not allow me to select it to delete it
Okay. on the bottom right, on the status bar you have 5 barrels. the 3rd starting from the left (select blocked elements) should present a red cross. click it and try again.. .
