TECNOMODEL
I press that they are the first times I have to deal with files created by others, first I modeled and made the mold so I never had these needs.
now I have a .step file sent to me by a supplier, the amount and opens me a set with different groups of surfaces.
from the environment together I can not correct and then merge everything.
the supplier says he exported it as solid, he uses toptron.
Did I do something wrong with the import parameters?
how to import it as solid? or to the limit as part where you can work on the surfaces, correct them and finally combine everything?
