importazione file
  • Thread starter Thread starter Sea17
Sea17
Hello.
I am a neophyte of creo parametric. importing a file part of solidworks, I lose reference plans and its views. same thing happens if, amount the same file in iges format, step, parasolid or other. How can I solve the problem?
I thank you in advance for the time you want to devote.
Say hi.
there is no solution, a step or iges file when exported saves only geometries.
all data related to materials and views is lost.
I do not remember if in the options of solidworks there is the possibility to export even the reference plans ... for what can serve.
the best thing in case of import is to create a new file and import the step or iges (with the data reuper command -> import) do not use file->open directly
this allows you to have the 3 floors and the 3 main side-plant-front views (of course if you have a preset start part appropriately)
n.b. in any case does not keep solidworks plans but better than nothing. . .
