OmarT
Good evening to all,
recently we started using inventor 2014 (standard version).
I have a problem.
we usually provide .x_t or .step files as 3d templates to create molds.
I open it by importing it into a new part and then I eliminate the faces that are not part of male(punzone) and matrix respectively creating 2 different parts. All right here.
create holes, screws etc.
the problem comes when I have to go to replace the imported solid starting.
Is there a "fast" or simple procedure to avoid having to recreate everything?? ?
Thank you very much
Omar
I have a problem.
Thank you very much
Omar
