Nigredo
Good morning to all,
I am having the following problem on catia:
are currently inside a catproduct containing two catparts.
I activated in the options - under part infrastructure - the check "keeps the connection with the selected object".
I have successfully created links between one catpart and the geometries of the other (works correctly and update according to external references as duty); However if I try to create a sketch within the second catpart does not allow me to project* or to select geometries of the other unless disable the check "conserve the connection with the selected object"; can therefore quota only on internal geometries to the same.
*in case you try to make projections the message "projection on the plan of the unsuccessful sketch: it is not possible to project the selected elements".
Is there a way to solve this problem or the limit of this function in the fact that it cannot create links from both sides? (reforming the question, is it normal that once you create references to a catpart I am unable to make the opposite and create references to the first catpart? )
Thank you in advance.
davide
davide
