you must select section 1 and section 2.a guide curve is not indispensable... But I don't understand where I'm wrong.
with catia I select 1st curve and 1st surface of tg and then 2nd curve and 2nd sup of tg, but therefore it does not go..
and what would be sections 1 and 2?you must select section 1 and section 2.
later if you want the driving curve.
or the extreme edges of the two surfaces to be connected? it does not go, neither with the edges, neither with the faces, nor with the edges and faces.. .Sections 1 and 2 are the initial and final sections you want to join with loft protusion
you are using the solid loft, for which you have to select a closed area.Hey, guys.
Can you tell me what I'm wrong?
I can't make the surface from loft (see attachment) despite the preview seems to show the correct path.
while using forgotten solidworks of caia, and vice versa. you will have many less porblems avoiding using the commands of one like the other.with catia I select 1st curve and 1st surface of tg and then 2nd curve and 2nd sup of tg, but therefore it does not go..
this is indicated by the tutorial. where do I find the loft command for surfaces?you are using the solid loft, for which you have to select a closed area.
you have selected two profiles so you have to use the surface loft, which you find in the surface controls.
I asked you the next question because I solved (the surface card was not there for this reason I confused the loft for solid with the one for surfaces, sympathetics :tongueAre you kidding?
What did you write in point 1 in the tutorial that you posted the screen? read the tutorials (and the relic help to the commands indicated) or just look at the figures?
but come on, since you were joking: I'm not pushing any further.. .
mistakes that actually non are following the indications, or rather the indications are related to a different phase (probably later) of the modeling compared to what you are doingif I follow the indication I do not join the surfaces.. What's wrong?
Sure for kindness and welcome you are not at the top I see,.. look for the surface tutorial and you will find the error.mistakes that actually non are following the indications, or rather the indications are related to a different phase (probably later) of the modeling compared to what you are doing
how can you expect to combine three surfaces that are disconnected with each other?
I repeat, when a command fails you click on the " icon?" and read the relative help. in your case you would have found written, just at the beginning, that (citely):"the edges of the surfaces must be adjacent and not overlapped. "http://help.solidworks.com/2011/ita...e.htm?id=29fcad5225f34f6184090b43302c0e5f#pg0if you use the forum as a help desk at the first difficulty without seeking help premium in the preposed places (the online help), in addition to using it badly, you will only lose great time unnecessarily. Today you're greedy that there's someone answering you, otherwise you'd be stuck last night for a bischer.
depends very much on the context and also on what your expectations are.Sure for kindness and welcome you are not at the top I see
There is no error in that tutorial. You make the mistake. I see now that from the images of your model you see that you are doing a tutorial dedicated to the surfaces using at first the loft commands and sweep of the solids that after you connect with surfaces and that you tend unnecessarily to join.look for the surface tutorial and you will find the error.
Prego...regarding the answer (for which I thank you anyway)
If you solved it yourself before receiving an answer you might be worthy to come here and write that you solved and how you did. to this serve the forums, not only to receive kind answers.Well really I had already solved by myself (clicking on the appropriate icon inserts me the missing commands, but very rarely I used it because I find them easily).
quietly, I do not break up and do not demand anything, whatever language you decide to use; I simply direct my answers accordingly. But I think you'd better focus on your problem, or the tutorial.(I don't want to, but if these are your tones, don't expect otherwise)
I have to repeat myself: tu that must read the tutorial carefully, not me.I was just saying if you read carefully the tutorial [...]you will realize that the same proposes me to combine surfaces that he himself cited me the need to be adjoining (which was not, and it was obvious and strange)
Actually, as I explained, you didn't follow it carefully, for what you can't do.and as I limit myself to follow step by step directions thinking that everything is correct.
actually you wrote that the tutorial is wrong, adding that I have to read it well...then place and I ask you thinking that I am wrong in something
Well, you wrote that the tutorial prepared by solidworks is wrong because you don't succeed, then you advised me to read it carefully so that I can confirm that you can't because it's wrong. as an example of humility there is no evil:wink:Is humility repaid?
I didn't notice. Why don't you tell me where the mistake is so I learn something, too?I assure you that there is an error of setting in the pages and in my opinion you have noticed but noble to say it.
Look, that tutorial to the point where you block it in a few minutes and it manages perfectly by closing the sides of the sprayer with the filling surface. if you like to argue that my attitude is not constructive do as well, but to me, following not my advice but the tutorial, the model succeeds.I ask you not to insert yourself into my posts if such must be your attitude all but constructive.
Here, we are, comes the classic overturning of frittata so it is the interlocutor that indicates where it is wrong that it has problems, it has to vent etc and follows the cry of asylum with "I tell the teacher". .I'm very sorry if you have problems and use the forum to blur, I hope some moderators notice it.
But I ask you to tell me precisely, if you are able to do so, where the mistake is. I'm always willing to change my mind.I do not lower myself to your level, but the error c is (the dassault is not god and can wrong the page), read rather than sow zizzania. .
Wake up! !(also from my print screen it was seen that I followed the directions,...
already, a guy who manages the tutorial you're wrong. The same guy who's explaining how to solve your modeling problem.What kind.
Look, I'm writing for you, not the opposite. I'll tell you what you're talking about and I'll show you.
This is the last I write for you.. because you are not constructive at all, point your finger with yours .. you.. you don't. And whoever reads realizes that, so you're wasting words like a desperate one.
Marcof said:But I ask you to tell me precisely, if you are able to do so, where the mistake is. I'm always willing to change my mind.
if you go get the only capture file3 posted and read carefully, it is asked to select 3 surfaces (from him not from me) that are not adjacent. . .
I hope you're clear now who's wasting words like a desperate man and begins to give in escandescences after doing bar psychoanalysis towards his interlocutor. I have limited myself to technical facts.and now stop shooting at chicchessia, avoid judging as you did from the beginning, never take anything for granted and think that those who read may have difficulties for many reasons; first listens to what comes from others without judgment and tries to understand, then, with grace and respect for intervening people.
Whoever reads I think will be with me.
We say that it must serve you to understand how you behave with someone who is giving you a hand, but you will understand it when you realize that you are wrong with modeling by making mistakes I have described to you several times. If you want to piss me off because I tell you that you read wrong the tutorial go ahead. It's not hot or cold.We have closed, I hope that at least this discussion will be served to understand how it behaves![]()
