impossible to create the connection between two surfaces nurbs
  • Thread starter Thread starter andr34
andr34
hello to everyone, I probably run away something, I created two cloud surfaces that I should connect with a tot radius bevel. but running the fillet tells me that it is impossible to create the connection between the selected surfaces. I attach a screenshot
are in autocad 2011.
Thank you, hello
try to realize the solid of revolution from a section, and maybe generate the connection already in the section phase, which you do first!
thanks ezio, but also with a surface of revolution "non nurbs" it lets me do the fillet, but if I put an output " nurbs" when I genero the surface, as in this case because I have to deform it acting on the cv, it does not allow me the fillet. in no case with the nurbs allows me the fillet and it seemed a bit strange to me this thing.
Wait for more injuries! even if it seems really strange is what, generally the result can be obtained with different methods of approach. I just suggested what my method would be. Maybe I explained badly! I suggested you create your profile with the connection already in the pre-revolution phase, in the simple 2d of the section of your solid! Once you get the desired mathematics, you convert it to nurbs!
not to misinterpret: when you say " 2 cloud surfaces" to what exactly do you refer to?
attach the dwg directly (possibly zipped), so we also try on the object.
Thank you very much,
I don't know if I understand what you told me but basically I just want to know if in autocad 2011 it is possible to connect between two nurbs surfaces.
then in this case I was doing only experiments, I tried to edit a revolutionary nurbs surface to give it a non-symmetrical and more organic form, acting on the cv.(for cloud surface I mean a generated surface by activating the "nurbs" output introduced with autocad 2011) .
Finally as you see in the drawing I closed with two flat cloud surfaces the two holes and I wanted to create the fittings of the two flat surfaces with the revolutionary surface, but autocad does not allow me.
Multifunction bar --> surface card\group change\connect
menu --> design\modelling\superfici\agreement
Goddamn, he had left a radius too big was for what he didn't collect. ok the umpteenth figure from pirla I made it but I'm glad to know that it is possible.
thanks gp and all the speakers. Good evening!
ps. from what I see you lose the association, that is, the possibility of editing, once applied, the radius of the chord.
...from what I see you lose the association, that is the possibility to edit, once applied, the radius of the connection.. .
by selecting the connection surface you can change the radius from the property window.
