impossible to explode block (ellipse, hatch, spline)
  • Thread starter Thread starter yag
yag
Hello
I have a problem with a dxf in practice I have to explode all the blocks (this because when I amount the dx inside another program I see in this program of strange circles over the design that I don't see in autocad) the first time to try to fix I exploded all the design by making select everything... and the unforeseen has appeared a huge block that I have promptly slaughtered this operation has made a circle that first appeared in the pogram in which I imported the dxf now is no longer present (but there are others) repeating the operation but I are given these messages
impossible to explode bloot ellipse
impossible to explode bloot hatch
impossible to explode bloot spline
I searched in this forum and tried the various suggested solutions but nn I came to head
So here I am... some ideas? some advice use autocad (old) 2007
only attaches the incriminated block if you have problems.... .
alternatively, you could try to save in dxf format, reopen it and see what it converted and what not. in any case, the ellipses cannot be exploded if they do not convert them into polylinese before.
I'm sorry I'm late in the answer. I basically have to convert everything to polylinea as I do it?
In practice I noticed that the design is a big block if I do from the menu select everything I see objects but if instead I do it by keyboard ctrl-a I see "objects" lines that before were not present and even visible (I see them selected with but I can not change anything ....
Expand the block, otherwise you can't convert anything!
and verify that all layers are lit and visible, maybe the strange lines or arches are located on frozen layers, you never know!
