Impossible to reinstall autocad 2013
  • Thread starter Thread starter dsp
dsp
salve ragazzi , qualcuno mi può aiutare???
uso diversi cad 3d come solid edge e inventor.
per mia cultura personale ho intenzione di studiarmi autocad , solo per cultura personale e senza scopo di lucro.
ho installato autocad 2013 dopo un primo coretto funzionamento alimproviso mi salta.
ho provato ad installarlo ma niente ecco quello che mi da:
qualcuno mi può aiutare?????
2013/7/28:08:47:22 pc pc-pc === setup started on pc-pc by pc ===
2013/7/28:08:47:22 pc pc-pc launch
2013/7/28:08:47:31 pc pc-pc === setup ended ===
2013/7/28:08:47:24 pc pc-pc === setup started on pc-pc by pc ===
2013/7/28:08:47:24 pc pc-pc launch
2013/7/28:08:47:32 pc pc-pc pageopen launchdialog
2013/7/28:08:47:43 pc pc-pc pageopen licensedialog
2013/7/28:08:47:55 pc pc-pc pageopen productinfodialog
2013/7/28:08:48:29 pc pc-pc pageopen productselectiondialog2
2013/7/28:08:51:54 pc pc-pc pageopen fullprogressdialog
2013/7/28:08:51:54 pc pc-pc installing directx runtime: g:\3rdparty\directx\dxsetup.exe /silent
2013/7/28:08:52:22 pc pc-pc install directx runtime succeeded
2013/7/28:08:52:22 pc pc-pc installing autocad® mechanical 2013: transforms="g:\x64\en-us\acadm\acad.mst;c:\users\pc\appdata\local\temp\_aif019.tmp\x64\acadm\acad-standalone.mst" adsk_eula_status=#1 muilang=en-us adsk_source_root="g:\" installdir="c:\program files\autodesk\autocad 2013\" filesinusetext="" reboot=reallysuppress adsk_setup_exe=1
2013/7/28:08:57:26 pc pc-pc install autocad® mechanical 2013 succeeded
2013/7/28:08:57:28 pc pc-pc installing autocad® mechanical 2013 language pack: transforms="c:\users\pc\appdata\local\temp\_aif019.tmp\_la29b7.tmp.mst" adsk_eula_status=#1 muilang=en-us muihidearp=1 adsk_source_root="g:\" installdir="c:\program files\autodesk\autocad 2013\" filesinusetext="" reboot=reallysuppress adsk_setup_exe=1
2013/7/28:08:59:01 pc pc-pc install autocad® mechanical 2013 language pack succeeded
2013/7/28:08:59:01 pc pc-pc installing autocad® mechanical 2013 product specific pack: installshortcuts=0 adsk_eula_status=#1 muilang=en-us adsk_source_root="g:\" filesinusetext="" reboot=reallysuppress adsk_setup_exe=1 transforms="c:\users\pc\appdata\local\temp\_aif019.tmp\media.mst"
2013/7/28:08:59:31 pc pc-pc install autocad® mechanical 2013 product specific pack succeeded
2013/7/28:08:59:31 pc pc-pc installing autodesk cloud sync: adlanguage=en-us adsk_eula_status=#1 muilang=en-us adsk_source_root="g:\" filesinusetext="" reboot=reallysuppress adsk_setup_exe=1 transforms="c:\users\pc\appdata\local\temp\_aif019.tmp\media.mst"
2013/7/28:09:00:21 pc pc-pc install autodesk cloud sync failed failure is ignored, result=1603
I've been having trouble reinstalling autocad... I solved using a very light utility: windows installer clean up, which serves to permanently erase the tracks and registry keys that a software leaves after a failed uninstall. before using it back up the log, and for security a restore point. Hi.
