impost texture su v-ray per rhino 4
  • Thread starter Thread starter lem8623
lem8623
Hello everyone, I am new here on this forum. I have a "problem", i.e. I can't set the textures on v-ray for rhinoceros 4.0. Who can help me please? Thank you so much in advance!!! ;)
material per layer can be set from the list of layers where "freedom of materials"
to edit the materials there is the appropriate material editor provided by the v-ray plugin
to associate individual objects instead it is necessary to specify it with the single selection under the "material" tag
But I don't know how much I can help you. . ♪
i.e. practically you do the same way as you set the material to the layer and then make the renders with rhino instead of with v-ray, right? or should I set it from the "circle" to the right of the layer!?!? ! ?
exact sisi, it works just as with the internal module of rhino rendering. .
only using vray materials:)
