in a 2d design enter a 3d
  • Thread starter Thread starter romi
hahaha, excuse me if I laugh but this is too general question!
the 3d must be built, starting from the 2d, with the extrusion of polylinee, use of boolean, trancia etc...
If you don't know anything about 3d I can suggest you buy a guide, follow a specialized course or follow you from a capable person.
Well, that the 3d should be built starting from the 2d, maybe there would also be my 5 year old nephew; having written only two lines, I actually let myself understand. I ask for vein, lattu. Therefore, I would like to insert a 3d model, in a 2d already finished. I don't know if that's feasible. the only road I know is to project the views on a floor. remains the only and only road or is there any command that transforms me a 3d design in 2d?
you can start with these videos, they are for 2010 but the solview and soldraw commands also work in 2007... :tongue:
http://www.youtube.com/watch?v=nqkrpwcrux8&feature=playlist&p=982fa5fdf7a8d334&index=1
http://www.youtube.com/watch?v=gkg1xgnco-w&feature=playlist&p=982fa5fdf7a8d334&index=0cation
p-h
I believe that the understanding refers only to the printing, es un design 2d wd a particular in 3d, in case you have drawn in the model space, you have to do nothing but divide the windows of a layout
the image simplifies what I want to express
However there are so many on the net just tryautocad paper space
compliments liber, you are one that makes useful and understandable examples! It has a 2d design and wants to add one in 3d! but copy and paste does not work? open your two drawings, cover the 3d and paste it into the 2d! Excuse me!
the problem is that our friend romi did not explain his problem properly and we were here to guess to find a solution
Thank you all! everyone has listed a probable solution, but they all go well! from that of pounds in print, copy and paste phase Entity, all excellent solutions! videos are good too p-h.
@ Have patience for the general question, last thing I am woman, in the profession you will notice: employed.
here you have written 2 chestnuts first donna This does not make you incapable of a man, indeed I have seen so many capable
the second Impregnated this in your ability to learn and learn does not exempt you from trying to improve your knowledge, and your level of professionalism
I still don't understand. . .
So you solved your problem? Do you have anything else to ask?
Yes, forgive me, at the time of the answer I did not notice.
Now it is not the case of lifting a useless dust.
instead of communicating more with users to avoid these situations in the future
My wish was to be a spurt not a reproach, even if offtopic, every person must never underestimate, but must give the best of himself, certainly there will always be someone better, but at this it will be remedied with constancy, dedication and time available, :smile:
@liber
lattu called romi "our amico"and she specified that she is female, and that the thing was deductible from the profession.
That's all. :smile:
@ poundsForgive me, but now you have created it! I know you don't even understand what Lattu says! Maybe you're gonna have to read your posts, which you're not sure going to do, because you're gonna understand this... you're gonna figure out that your answer is really useless! the fact that I specified to be woman and employed is only to give an answer to lattu that initially took me for a man. What? ?
@ Yes, I solved in the procedure illustrated by liber, thank you.
@ gp Thank you for highlighting the problem. Now the good liber will certainly have understood.
Okay! :rolleyes:
another system could be seen that you have autocad 2007,
and maybe you want to stay only in the model space, is print the 3d in the view you want in dwf format, and then import it into the drawing as reference
Hello everyone..... .
Excuse me, but I can't solve my problem by your messages.
I would like to get the result shown in the photo posted by liber, but not in print, but in the .dwg model.
I practically have a particular designed in a 2d table and in a 3d, now in model 2d I want to insert an assonometric view of the 3d.
I use autocad2004.... do you give me a hand?
in the model you can insert your 3d, but that view is in the table setting, layout or as it was called before paper space the spacecarta/lauout you can divide it as you like and in the scale that best suits you, it's like having so many autocad windows where in the first zoom on the 2d you like, and make the orbit in the window that best suits you, for the info on how to set spacecarta/layout just do a little research and find everything.
