in the file menu do not find the "save" command
  • Thread starter Thread starter valtic
valtic
Good morning to all,
I have a small/big problem.
I have just installed catia v5 r21 and in catpart environment as in other environments in the toolbar --> file --> I do not find the function "save" or at least "saving management", and maybe even import, in short, there are a few voices missing.
what I see is only:
- New.. .
- New from...
-Open...
--chiudi.. .
--print.. .
- Printer tax. . .
--desk.. .
--property of the document
I also took a look in the menu customize but with negative outcome.
How can I do that? Do you have an idea?
Same problem! !
v5 6r2012 version.
Does anyone have any idea how to solve the problem? ! ?
then I want advice:
never use zna version without at least the service pack 03
in your case perhaps the catsettings are corrupted
try to laugh
No, I don't think I'm finding any mistakes in catsettings. where you think it might be the problem.
Hello and thank you.
try to erase them completely (before a backup) and restart catia with the original setting
done. Now it's all right. ?
Thank you so much!! !
Hello, marig,
I found the same problem with a v5-6r2015, would you be so kind to explain to me the steps of resetting catsetting? I have to do an exam but I can't get out of it. Thank you in advance.
the folder where catsetting resides and a hidden folder and in win7 is c:\users\???? ? \appdata\roaming\dassaultsystemes
after users put the user with whom you enter windows
Hello, everyone.
I have the same problem described here and I can't solve it. Can someone tell me a solution?
try to delete catsetting, they are usually in the directory: c:\users\tuonome\appdata\roaming\dassaultsystemes (the exact address depends on environment variables) and contain caia configuration settings, then search the folder and fan a security copy, then delete all content and start caia.
You have to find the folder that is sometimes hidden. search on google how to make hidden folders visible and then do the search.
I had already tried after reading the previous answers, but nothing. Is there any files in particular to delete? I forgot to say I use catia v5 r2015.
a curiosity: Is it normal to have to select all licenses again after deleting catsetting?
all catsetting that are in the folder
Indeed, as catsettings are the settings of all parameters (licenses, icons, views etc.) related to installation (in fact I wrote to make a security copy and if the attempt fails to restore them).
then change everything: this is the forum catia v5 catpart, and the answers are for v5, while you are asking for information of catia v5 6r2015, very different product, which (I think) does not allow to save the files individually as we are used to doing, but manage everything on a server in a way not defined by the single user.
I don't know him and I can't help you.
I disagree with catia v5 6r2015 is nothing but v5r25. 6 of catia v5 6r2015 indicates that the version is compatible with the new v6 platform known lately in 3dexperience.
management of catsettings in catia v5 6r2015 remains the same as in previous versions <r24.
at the limit a320 could you post a session magnet when you open a .catpart?
I disagree with catia v5 6r2015 is nothing but v5r26. 6 of catia v5 6r2015 indicates that the version is compatible with the new v6 platform known lately in 3dexperience.
I was misinformed, thank you for clarifying.
years ago
[MENTION=114]falonef[/MENTION]: I really don't feel anything trying to open one of those files.
[MENTION=58722]marco.bello1984[/MENTION]: I also tried the reset road, but nothing.
open a catpart, try to save and make an image capture and places along with the version and service pack
