in the me2011
  • Thread starter Thread starter FIGOR71
FIGOR71
Hello, everyone. .
How can I see the bending lines of a simple chord (round square) in the table of solidworks 2011? with display nn tangent edges works.. .
already ke there are I ask even if qlcn knows how to insert the mass property(the weight)automatically always in the table.
see image attached
Hello, everyone. .
see image attached
If you have designed the hopper with the loft bending function (with all the rules of the case) you should be able to view everything with the option you have activated.
I'm afraid you drew the loft with some mistake.
I'll give you an example.
for weight, on the side: file/property and add mass voice.
Make sure you have given him the material in the building tree.
on the drawing you will call back that voice through the connection to the properties from the property manager.
ok probabilmento I wrong to do the round sketch, even xkè I tried to do it again and nn I can get nothing. . .
possible ke to make a hopper you need such a complicated sketch? in inventor there were 2 sketches, one round and one square, without needing to cut them or radiate them or add other it was enough to select them say how many folds the thickness (inside or outside) and the game was made.. .
I'm fighting a little longer and then I see what I get
Thanks again.. .
Can I keep you in mind for other problems?
on, from it is not so complicated, they are 8 entities and they draw in a moment. every cad has qualities and defects, I am studying inventor and I am marking the qualities and defects that I find on a table excel. Of course that in my case, having experience with swx, I see more defects than the merits, but as a modeler swx seems to me much better.
This function is to the advantage of inventor, there is nothing to say and I will also mark it in my table.
mike is always very competent and helpful, however if you have doubts about some features, mail that one or the other we give you a hand:finger:
Thanks again.. .
sire has already answered your questions, I repeat availability within technical limits and
time available. . It's been a case lately...
:smile:
I managed to set the mass property, only ke inserts the grams and nn in kg as set in the options mass properties of the axieme.
Is there a solution?
Yes, you must go (in part, not in the table) in options -> document properties -> units and set as from attached image. If you always have chilies, you should save the part template and also that of the assemblies with its settings, to also have the weight in kg.
Andrea
