In the Tavola Salda
  • Thread starter Thread starter d-prom
d-prom
Good morning, everyone. I would like to speak of a problem in the representation of the welding cords at the table. I go to a view, I click with the right button, select "good model annotations" and then "good welding notes". of the welds present in the model, if all right, they appear a part, the others I have to put them by hand. I never understood why. I'm currently working with 2012, but the problem is also with 2013: it's a kiss (at least I think it's a kiss) that inventor has been taking a long time, and I don't understand why he hasn't intervened to fix it. Did someone find the same problem?
thanks to everyone in advance.
That's what pisses me off, but there's no way, sometimes it doesn't work for very simple normal strings!
Well, I understand, but since it's a flaw that inventor has been carrying behind, I always think, what are they waiting to fix it?
hi yes the problem is known, who knows why there is then a special command :)) is manual is clear though if you just want to see the cord in those soldering that does not do it helps, it is called a thousandfold welding you find it under user symbols
... that makes enough to fall too... .
I know the command "1000piedi", but the problem is another: why don't weld automatically? who are waiting to fix the problem?
If I buy a car and that doesn't work, I know that I can push it or stick it in front of a donkey and make it pull, but since I bought it and paid for it working, I would like it to walk with its engine.. .
Do you want the truth?? :
we are like the children of the mother, at every new release a new toy to try
No, it's not like that, this command has been there for years and I've never worked as you must and not even the millepid. Just like any "consumer" if you give me the command, give me that it works.
it has been there for years and it would now be reviewed as the possibility to copy and paste a sheet of a table that actually copy there is missing the ii glue key....but what I meant ironically is that the problems and improvements to do, autodesk knows them very well, but for their internal policy you will never have a perfect product to 100% would not explain senò the release of a new version every year making you update
