Fulvio Romano
Okay, I need help, but I'm ashamed.
we have a ball on a sloping surface. If the plan is straight I'll take some time. If the surface is curved I will put on? More? less? and friction with the air how does it affect the thing?
Intuitively I assumed that, considering friction with air, the tilted plane is the shortest route because the one that maintains a lower average speed and therefore globally less wasted energy.
I tried to mathematically derive the hourly equation according to the surface, but I lost myself in the calculations.
I tried to mathematically derive the equation of energy, but nothing comes out.
In the end, as a mechanical hub, I did a simulation in matlab. I confirm that by high viscous coefficient the best way is straight, but with viscosity nothing exists faster when the surface begins to curve, and then returns disadvantageous.
attached you see the simulations with sigma equal to 0, 5 and 10. in each diagram you can see the sliding surface, acceleration, speed and position.
who helps me better understand this phenomenon?
