inclined walls
  • Thread starter Thread starter solenoideqq
solenoideqq
happy day to all!! !
I have to realize the clover building of bridges..... on the basement floor has external walls tilted of 11°.
Now I have made the walls, but straight... how do I tilt them by 11°? ? ?
Moreover the inner soles are also inlclined those according to the classic solo of the university classrooms, with chair in the lower and benches to rise...(type theater). . .
If you'd help me, I'd like a good favor.
Thank you all! Hi.
Bye-bye, let's go. As for the sloped walls you can use two methods.
1 - create an in-place tilted wall with the command creates. you can choose between a union (of two horizontal rectangular profiles, of course of different thicknesses calculated in order to have the desired inclination) or an extrusion on the path.
2 - create a mass of volumetrics, which will have a tilted face, then choose to create a wall from the surface, choosing between the types of walls.
See a little.
aaaa okok works x the walls...... but I did the mass you told me, I made wall by face.....only that now I can't attack the old walls to the new ones made in this way....neanche with attach... .
Do you have any lighting for the floors? thank you 10000 hi
Hello everyone.. .
given my ignorance I would like to know how to build a sloping walls....I read other answers to things like that but don't go understood much!!! !
Thank you! ! ! !
Hello everyone.. .
Thank you! ! ! !
... what did you not understand?
hi gfrank I managed to make the wall but at this point I ask you politely if you can tell me how to do the tilted windows and even the continuous facades. Hi.
windows families, by default, use a vertical plane, and normally are also in tilted mutes. it is possible that the "empty" in the family of the windows is necessary, so that the whole width of the wall "holes".
I never tried to make them.
p.s. writing in capital is equivalent to shouting. always uses the minuscule character
