incorrect design link
  • Thread starter Thread starter GiGa
GiGa
I'd like to try to solve a problem with a table of meetings that have passed me. Unfortunately, they were made "very handicraft" and now they create big problems on file paths (in the process of writing they didn't even create the project file and saved in always different folders). in practice, opening the file is returned the unsolved document error and replaced with a present in the work area. in case you accept replacement, it is given cyclic redundancy error and the table loses most views and quotas. If instead you try to indicate the new file, the selection window proposes "infinite"... only with "unignora" you can move on. the table (complete in views and quotas) but preserves the original path that obviously is no longer valid. Trying to fix the link, reboots the "infinite" window... that there is a way to recover the file?
is it possible to rename the document with which inventor replaces the right file? so doing should ask you the path of the unsolved file.
It is also possible, using the options at the time of the opening of the table, to postpone updates and ignore the unresolved files: Maybe at open table you can make a reference model replacement.
I hope not to have answered the wrong questions :-)
I tried in every manner, but he doesn't leave... 99% of the problem is due to the fact that in the connected axieme they have inserted twice the same component for having it in view even if already present as a reference... a little complicated to explain... Let's say who did the boards, used a cure worse than evil to cure... Fortunately it was not too complex and they did it again losing little time.
