incorrect display in windows revit
  • Thread starter Thread starter ocraM999
ocraM999
Until now I didn't notice but I realized that revit doesn't display windows properly.... .
I'll explain.
I'd like to make a window of the same kind as the one I downloaded from the network. It is a fixture composed of different mirrors supported by pillars and beams. what you see makes the idea good. if you see the display in the plant of this kind of infix, revit seems to confuse the various parts that make up it showing illogically what is hidden and hiding what should be visible.
in the image attached the 3d view shows the cutting plan to 1,20 highlighting in this way what you would expect to be cut while the two views in the plant, one with cutting plan to 1.2 the other higher to 1,80 , show erroneously the fixture.
the error remains acting on the parameters of this kind of infix and also on the depth of the view.
...it's a little complicated to explain ..... I attach the file.. .
Mar
  • Progetto2.zip
    Progetto2.zip
in the project browser select the view in the floor plan and from the palette of properties click on change... in extensions > display range
