incorrect import of spline
  • Thread starter Thread starter Gabryn
Gabryn
Hello, everyone.
Sorry for the question perhaps trivial, but I can't understand the following:
from coreldraw carry a .dwg file composed mainly of splines:
if the amount in autocad I see some parts slightly deformed while if
the amount in solidworks I see it correctly (as the original).
Can you tell me why?
in acad (2012) I tried to increase the accuracy of strings and polylines but nothing changes:frown:
I restored default settings, but nothing... .
I attach a preview (over the "s" deformed and under "s" right) and the two files.
Gabriele
in the dwg of corel the spline is whole (and then closed), while with swx is divided into portions.
I confirm your results if I open them with 2012, but with 2014 it is all regular, they are both accurate.
thanks for the interest gp.
In fact even with draftsight (last version) the import is correct... but then I have no way to "explode" the spline with the "flatten" command of autocad.
However you have already given me useful information about v.2014.
Gabriele
