Thank you so much tristan.it is possible; use a surface style in which the gradient analysis is visible, then the "analysis" tab of the surface properties sets the various ranges
I solved! thanks cmq, helloThank you so much tristan.
I would also need to have a table of range of gradients (with various intervals). In practice I must highlight the areas of a slope that have excessive slopes for the installation of photovoltaic panels.
how beautiful the spirit of sharing. . . .I solved! thanks cmq, hello
surface properties --> type of analysis --> slopes indicate the number of intervals and in the detail part range mark a minimum slope and a maximumhow beautiful the spirit of sharing. . . .
Why do you create a static legend?for the table: select the surface, from the menu add legend --> gradients --> static
Right, thank you! Hi.Why do you create a static legend?
