indication of certain areas with retinals/fields
  • Thread starter Thread starter Andre75
Andre75
Good morning to all,
I would have the need to create on some views of the design of the areas delimited by retini/capitures that serve to insert notes (example painting of a given type)
I'm putting an example for "better shots."
  • esempio.PDF
    esempio.PDF
create the frame that interests you (circle or picture) in drawing 2d then with the click button above the frame (i.e. you make it red) then button dx sampling/filling, enter the name you want - sending.
I tried but the only options that appear to me are the ones in the picture.
Is it an option that also works on wf2?
I don't know why I didn't install it... we hope in an answer from those who still use wf2.
memory because I didn't even install it.
I think once you have selected your closed contour, click in the edit menu and there should be the filling or sampling item no longer remember.
However there is 100 %
Ozzy!
from the menu change-> Fill
then there is the sampled or plain color option
thanks to all
Ozzy!
thanks to all
I was almost there. :smile:
you can sample it or fill it. :-)
I am pleased that memory still works.:biggrin:
